raid.stripe events
raid.stripe.replay.bad.block
- Severity
ERROR
- Description
This event is issued when we encounter a bad block buffer entry in NVRAM during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
- Corrective Action
Need to replace NVRAM if observed repeatedly during different boot-ups.
- Syslog Message
Bad block buffer entry in NVRAM.
- Parameters
(None).
raid.stripe.replay.bad.checksum
- Severity
ERROR
- Description
This event is issued when we encounter a checksum error in NVRAM during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
- Corrective Action
- Syslog Message
Checksum error in NVRAM.
- Parameters
(None).
raid.stripe.replay.bad.key
- Severity
ERROR
- Description
This event is issued when we cannot find a block buffer using a key during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
- Corrective Action
- Syslog Message
Stripe %llu: cannot find NVRAM slot using key %d in %s %s.
- Parameters
stripe (LONGINT): The stripe number.
key (INT): The key used.
vol_type (STRING): Volume type.
vol (STRING): Aggregate name if found, otherwise NOT FOUND.
raid.stripe.replay.bad.stripe
- Severity
ERROR
- Description
This event is issued when we encounter a bad stripe entry in NVRAM during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
- Corrective Action
- Syslog Message
Bad stripe entry in NVRAM.
- Parameters
(None).
raid.stripe.replay.nvgen.mismatch
- Severity
NOTICE
- Description
This message occcurs when RAID encounters an NVRAM generation mismatch for an aggregate during stripe replay. Reparity will start automatically and update parity in stripes involved in recent writes.
- Corrective Action
(None).
- Syslog Message
NVRAM generation mismatch for %s %s%s.
- Parameters
owner (STRING): Owner of the affected aggregate.
vol (STRING): Name of the aggregate.
raid.stripe.replay.plex.unavailable
- Severity
NOTICE
- Description
This message occurs when RAID encounters an NVRAM stripe entry for an offline or failed plex during stripe replay. Reparity will start automatically when the plex comes online. At that time, reparity will update parity in stripes involved in recent writes.
- Corrective Action
(None).
- Syslog Message
Plex %s in %s %s%s is offline or failed.
- Parameters
plex (STRING): Name of the plex.
raid.stripe.replay.pzero.mismatch
- Severity
ERROR
- Description
This event is issued when the checksum of the parity block (as stored in the stripe slot) does not match the actual checksum of the parity block. This indicates corrupted NVRAM contents. Reparity will start automatically and update parity in stripes involved in recent writes.
- Corrective Action
- Syslog Message
Parity block checksum mismatch detected in NVRAM for stripe %llu in %s %s.
- Parameters
raid.stripe.replay.rg.failed
- Severity
NOTICE
- Description
This message occurs when RAID encounters a RAID group failure during stripe RAID replay. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
- Corrective Action
(None).
- Syslog Message
Replay of %s %s%s, plex %s, RAID group %s, stripe %llu failed because of RAID group failure.
- Parameters
rg (STRING): Name of the RAID group.
stripe (LONGINT): Stripe number.
raid.stripe.replay.rg.invalid
- Severity
NOTICE
- Description
This message occurs when RAID encounters an NVRAM stripe entry for a missing RAID group during stripe replay.
- Corrective Action
(None).
- Syslog Message
Invalid RAID group identifier %d in %s %s%s, plex %s.
- Parameters
rgid (INT): Identifier of the RAID group.
raid.stripe.replay.summary
- Severity
INFORMATIONAL
- Description
This event is generated when stripe replay is complete.
- Corrective Action
(None).
- Syslog Message
Replayed %u stripes.
- Parameters
nstripes (INT): The number of stripes
raid.stripe.replay.vol.cleanly.shutdown
- Severity
NOTICE
- Description
This message occurs when RAID encounters an NVRAM stripe entry for a cleanly shutdown aggregate during stripe replay.
- Corrective Action
(None).
- Syslog Message
%s %s%s was cleanly shut down.
- Parameters
raid.stripe.replay.volume.missing
- Severity
NOTICE
- Description
This message occurs when RAID encounters an NVRAM stripe entry for a missing aggregate during stripe replay. Reparity will start automatically when the aggregate appears again. At that time, reparity will update parity in stripes involved in recent writes.
- Corrective Action
(None).
- Syslog Message
Cannot find aggregate with identifier %s.
- Parameters
volId (STRING): Identifier of the aggregate.
raid.stripe.replay.volume.offline
- Severity
NOTICE
- Description
This message occurs when RAID encounters an NVRAM stripe entry for an offline aggregate during stripe replay. Reparity will start automatically when the aggregate comes online. At that time, reparity will update parity in stripes involved in recent writes.
- Corrective Action
(None).
- Syslog Message
%s %s %s is not online.
- Parameters
