rdb.sql events
Creating your file...
rdb.sql.upgrade.failed
- Severity
ERROR
- Description
This message occurs when the cluster management Data Replication Module could not upgrade its database from RDB to SQL.
- Corrective Action
Contact Contact NetApp technical support. for assistance.
- Syslog Message
Error: %s. Unable to upgrade the local database from RDB to SQL of Data Replication Module: %s.
- Parameters
message (STRING): Error message.
unit (STRING): Unit that failed the upgrade.
rdb.sql.upgrade.succeeded
- Severity
NOTICE
- Description
This message occurs when the cluster management Data Replication Module upgrades its database from RDB to SQL.
- Corrective Action
(None).
- Syslog Message
Successful upgrade of the local database from RDB to SQL of Data Replication Module: %s. Duration: %s sec Tables: %llu Records: %llu
- Parameters
unit (STRING): Unit that finished the upgrade.
duration (STRING): Duration of the upgrade in seconds.
tables (LONGINT): Number of tables processed.
records (LONGINT): Number of records processed.
