ONTAP EMS reference
repl.gsr events
repl.gsr EMS events occur when ONTAP encounters issues associated with SnapMirror Granular Sync operations.
repl.gsr.cache.modify.gs.enfrc.failed
Severity
ERROR
This message occurs when SnapMirror faces internal error while going Out-Of-Sync or source volume comes online.
Corrective Action
Resynchronize SnapmMirror sync relation. Please contact NetApp technical support for more options.
Syslog Message
Unable to modify enforcement for the sync granset relation.
transferId (STRING): UUID of the SnapMirror® transfer.
srcCgUUID (STRING): Source CG UUID.
Code (INT): Error code.
repl.gsr.clone.replication
Severity
NOTICE
This message occurs when replication of a clone request fails or cannot be serviced. The clone request completed successfully on the sync mirror primary, but was not completed on the sync mirror secondary. The clone will not be available on the sync mirror secondary.
Corrective Action
For further information about correcting the problem, see the Knowledgebase article #.
Syslog Message
Failed to replicate clone of /vol/%s/%s to sync mirror secondary.
volname (STRING): Volume name.
filename (STRING): Source filename.
reason (STRING): Descriptive reason for the notice.
repl.gsr.snap.replication.failed
Severity
INFORMATIONAL
This message occurs when a Snapshot® replication request fails or cannot be served.
Corrective Action
(None).
Syslog Message
Failed to replicate snapshot operation to the destination.
srcVolumeDsid (LONGINT): Source volume data set ID (DSID).
snapshotName (STRING): Name of the Snapshot copy to be replicated.
failureReason (STRING): Reason for the failure.
replStatus (INT): Replication Status.
replFailureMsg (INT): Replication failure message.
replFailureMsgDetail (INT): Replication failure message detail.
