repl.logical events
repl.logical.dw.rebuild
Severity
INFORMATIONAL
This message occurs when a data warehouse is rebuilt as part of a SnapMirror® restore or resync operation.
Corrective Action
(None).
Syslog Message
A data warehouse rebuild was performed on volume with name %s, MSID %llu, DSID %llu, and Vserver ID %u.
volName (STRING): Volume name.
volMsid (LONGINT): Volume master data set ID (MSID).
volDsid (LONGINT): Volume data set ID (DSID).
volVserverId (INT): Volume Vserver ID.
repl.logical.lreTolrse
Severity
INFORMATIONAL
This message occurs when previously enabled compression is disabled on the destination volume of a SnapMirror® relationship with the type XDP, and when it is followed by the "snapmirror update" command with the "enable-storage-efficiency" parameter set to "true". All future transfers to this destination volume from the current source will preserve storage efficiency as long as compression is disabled on it.
Corrective Action
(None).
Syslog Message
All future transfers from the current source to destination volume %s%s with MSID %llu, DSID %llu, from the current source will preserve storage efficiency as long as compression is disabled on the destination volume.
dstVolName (STRING): Destination volume name.
dstVolVserverUuid (STRING): Destination volume Vserver ID.
dstVolMsid (LONGINT): Destination volume Master data set ID (MSID).
dstVolDsid (LONGINT): Destination volume data set ID (DSID).
repl.logical.lrseTolre
Severity
INFORMATIONAL
This message occurs when compression is enabled on the destination volume of a SnapMirror® relationship that has type XDP. All future transfers to this destination volume from the current source will not preserve storage efficiency.
Corrective Action
(None).
Syslog Message
All future transfers to destination volume with MSID %llu, DSID %llu, and Vserver ID %u, from the current source will not preserve storage efficiency.
dstVolMsid (LONGINT): Destination volume Master Data Set ID (MSID).
dstVolDsid (LONGINT): Destination volume Data Set ID (DSID).
dstVolVserverId (INT): Destination volume Vserver ID.
repl.logical.rawDirToLogicalDir
Severity
INFORMATIONAL
This message occurs when a SnapMirror® transfer uses logical mode after a previous transfer to the same destination used raw directory mode. This most frequently occurs when the source node of the transfer was upgraded to a newer version of Data ONTAP® than the destination node.
Corrective Action
(None).
Syslog Message
(None).
dstVolClusterId (STRING): Destination volume cluster Universally Unique ID (UUID).
srcInstanceImageUuid (STRING): Source transfer instance Snapshot(tm) copy UUID.
srcVersionImageUuid (STRING): Source transfer version Snapshot copy UUID.
rawDirsSupported (INT): Indicates whether the destination believes raw directory transfer is supported.
rawDirsRequired (INT): Indicates whether the destination believes raw directory transfer is required.
