The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
repl.send events
Creating your file...
Your file is ready
repl.send.mgr.forcedLogical
- Severity
INFORMATIONAL
- Description
This message occurs when a SnapMirror® transfer uses logical mode without even attempting raw directory negotiation.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
srcVolMsid (LONGINT): Source volume Master Data Set ID (MSID).
srcVolDsid (LONGINT): Source volume Data Set ID (DSID).
srcVolClusterId (STRING): Source volume cluster Universally Unique ID (UUID).
srcVolVserverId (INT): Source volume Vserver ID.
srcInstanceImageUuid (STRING): Source transfer instance Snapshot(tm) copy UUID.
srcVersionImageUuid (STRING): Source transfer version Snapshot copy UUID.
srcInstanceRefImageUuid (STRING): Source reference instance Snapshot copy UUID.
srcVersionRefImageUuid (STRING): Source reference version Snapshot copy UUID.
