replication.dst events
replication.dst EMS events occur when ONTAP encounters issues associated with SnapMirror® or SnapVault® destination operations.
replication.dst.attrsNotSaved
- Severity
ERROR
- Description
This message is issued at the end of a Qtree SnapMirror® or SnapVault® transfer or checker/fixer operation when the replication destination detects that the replication source has sent file attributes that the replication destination does not support, and the replication destination has not saved those attributes. This may happen when the replication source is running a newer version of Data ONTAP® which supports file attributes that the replication destination does not support.
- Corrective Action
To store all of the attributes, upgrade your replication destination filer to a version of Data ONTAP which is at least as recent as the source. Alternatively, this message can be suppressed for all future transfers or checker/fixer operations for all Qtree SnapMirror and SnapVault relationships by setting the hidden replication option, suppress_attrs_not_saved_warnings.
- Syslog Message
The replication destination was unable to replicate all file attributes on %d file(s) or director(y/ies) in %s because it does not support one or more of the attributes sent by the source.
- Parameters
attrs_not_saved (INT): The number of files for which the replication destination could not replicate all file attributes.
dst_path (STRING): Destination qtree path.
replication.dst.debugLog
- Severity
ERROR
- Description
This message occurs when a SnapMirror® or SnapVault® destination cannot log the replication protocol header for the data received.
- Corrective Action
The reasons for the error cited in the error message might indicate ways to address the problem.
- Syslog Message
Logical Replication header log: %s %s:%s.
- Parameters
reason (STRING): Reason for the failure.
file_name (STRING): Logging file for which the error was encountered.
errstr (STRING): Error encountered during logging operation.
replication.dst.err
- Severity
ERROR
- Description
This message occurs when the system detects an error on a SnapMirror® or SnapVault® destination volume or qtree.
- Corrective Action
(None).
- Syslog Message
%s: destination transfer from %s:%s to %s : %s.
- Parameters
rtype (STRING): Replication type (SnapMirror, SnapVault, and so on.).
srcfiler (STRING): Replication source system.
srcpath (STRING): Replication source volume or qtree.
dstpath (STRING): Replication destination volume or qtree.
error (STRING): Specific error message.
replication.dst.inodeMissing
- Severity
ERROR
- Description
This message occurs when a file for which the replication source sent data is not present on the replication destination.
- Corrective Action
Check for WAFL® inconsistencies on the replication source.
- Syslog Message
The replication destination could not find the file corresponding to %d sent from the replication source. Check for WAFL inconsistencies on the replication source %s:%s.
- Parameters
inode (INT): Inode number of the source file for which the corresponding file is not present.
srcpath (STRING): Replication source path.
replication.dst.langMismatch
- Severity
ERROR
- Description
This message occurs when the user continues with the updates of the replication relationship after changing the language setting of the volume in which qtree replicas are configured or that contain replica primary.
- Corrective Action
Create a new baseline for the relationship.
- Syslog Message
Volume language was changed before this transfer or it was changed before some previous update transfer for the relationship of qtree %s. This might create some problems with further replication transfers of the relationship.
- Parameters
qtpath (STRING): Destination qtree path.
replication.dst.lostACL
- Severity
ERROR
- Description
This message occurs when a replication update discovers that an inode that is supposed to have an ACL does not have one, causing the replication to fail.
- Corrective Action
If the replication destination is a SnapMirror® destination, run the 'snapmirror quiesce' command to quiesce the replication relation, then run the 'snapmirror check -F' command under the guidance of NetApp technical support. If the destination is a SnapVault® destination, run the 'snapvault check -F' command under the guidance of NetApp technical support.
- Syslog Message
Replication transfer from %s:%s to %s:%s: the destination could not find ACL %d for source inode %d.
- Parameters
dstfiler (STRING): Replication destination system.
dstpath (STRING): Replication destination path.
acl_inode (INT): Inode number of source ACL.
file_inode (INT): Inode number of the replication source file.
replication.dst.noCommonSnap
- Severity
ERROR
- Description
This message occurs when a SnapVault® or SnapMirror® relationship cannot be resynchronized because there is no usable Snapshot(tm) copy that the source and destination have in common. In such situations, the 'snapvault start -r' and 'snapmirror resync' commands cannot be successfully completed.
- Corrective Action
The relationship cannot be resynchronized so it must be reinitialized. For SnapMirror, use the 'snapmirror initialize' command. For SnapVault, use the 'snapvault start' command. Either run the baseline transfer to a new qtree, or remove the existing qtree before starting the transfer. Refer to the Data Protection Guide for details.
- Syslog Message
%s: destination transfer from %s:%s to %s:%s : no common Snapshot copy to use as the base for resynchronization.
- Parameters
rplerror (STRING): Replication error message.
waflerror (STRING): WAFL® error
replication.dst.noMemory
- Severity
ALERT
- Description
This message occurs when there is insufficient memory on the SnapMirror® or SnapVault® destination for the transfer to continue.
- Corrective Action
(None).
- Syslog Message
System is low on memory; aborting %s destination transfer.
- Parameters
replication.dst.noSrcSnap
- Severity
ERROR
- Description
This message occurs when a SnapVault® or SnapMirror® destination discovers that the relationship's base Snapshot(tm) copy no longer exists on the source. In such situations, 'snapvault update' and 'snapmirror update' commands cannot execute successfully.
- Corrective Action
For SnapMirror, issue the command 'snapmirror resync' to make SnapMirror attempt to resynchronize the relationship. If the resync operation cannot find a common Snapshot copy, you must reestablish the relationship with the 'snapmirror initialize' command. For SnapVault, issue the command 'snapvault start -r' to make SnapVault attempt to resynchronize the relationship. If the 'snapvault start -r' command cannot find a common Snapshot copy, you must reestablish the relationship with the 'snapvault start' command. If you must reestablish a relationship, either run the baseline transfer to a new qtree, or remove the existing qtree before starting the transfer. Refer to the Data Protection Guide for details.
- Syslog Message
%s: destination transfer from %s:%s to %s:%s : base Snapshot copy for transfer no longer exists on the source.
- Parameters
waflerror (STRING): WAFL® error.
replication.dst.resync.failed
- Severity
ERROR
- Description
This message occurs when a SnapMirror® or SnapVault® resync operation is not successful.
- Corrective Action
See error message.
- Syslog Message
%s resync of %s to %s:%s : %s.
- Parameters
error (STRING): Error message.
replication.dst.resync.success
- Severity
NOTICE
- Description
This message occurs when a SnapMirror® or SnapVault® resync operation is successful.
- Corrective Action
Operation successful; no corrective action required.
- Syslog Message
%s resync of %s to %s:%s was successful.
- Parameters
replication.dst.setACLError
- Severity
ERROR
- Description
This event occurs when Data ONTAP encounters an illegal data stream during a logical backup operation. This is usually due to an OSSV primary software bug. Normally OSSV sets an ACL (Access Control List) on a regular file or directory. However, as a result of this bug, OSSV attempts to set an ACL on an Alternate Data Stream (ADS) of a file or directory. See bug 148879 for details.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
src_base_inum (INT): The base inode number generated by the source. The source is trying to set an ACL on this inode, which happens to be a stream.
dst_base_inum (INT): The corresponding base inode number on the destination.
replication.dst.setACLFailed
- Severity
ERROR
- Description
This message occurs when Data ONTAP® encounters an error while setting an ACL (Access Control List) for an inode on a SnapVault® or SnapMirror® destination. The replication transfer is aborted upon encountering this error.
- Corrective Action
(None).
- Syslog Message
Replication transfer from %s:%s to %s:%s: The destination failed to set ACL %d for source inode %d on destination inode %d. The replication transfer is aborted.
- Parameters
acl_inode (INT): Inode number of the source ACL.
src_base_inum (INT): Base inode number generated by the source. The destination is trying to set an ACL on this inode.
dst_base_inum (INT): Corresponding base inode number on the destination.
replication.dst.throttleChange
- Severity
NOTICE
- Description
This event is issued when the replication source, receives a request from the destination to change the current throttle value.
- Corrective Action
(None).
- Syslog Message
Throttle value changed to %d Kbytes/s for destination %s:%s
- Parameters
throttle (INT): The new throttle value.
dstfiler (STRING): The SnapMirror destination filer
dstpath (STRING): The SnapMirror destination volume or qtree
replication.dst.throttleChange.err
- Severity
NOTICE
- Description
This event is issued when the replication source, receives a request from the destination to change the current throttle value, but failed to complete the operation.
- Corrective Action
(None).
- Syslog Message
Failed to change throttle value to %d Kbytes/s for destination %s:%s : %s
- Parameters
error (STRING): The error message
replication.dst.waflErr
- Severity
ERROR
- Description
This message occurs when the system detects an error on a SnapMirror® or SnapVault® destination volume or qtree due to WAFL®.
- Corrective Action
(None).
- Syslog Message
%s: destination transfer from %s:%s to %s : %s:%s.
- Parameters
rplerror (STRING): Specific replication error message.
waflerror (STRING): Specific WAFL error message.
