The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rsh.firewall events
Creating your file...
Your file is ready
rsh.firewall.policy.remove
- Severity
NOTICE
- Description
This message occurs when rsh is automatically removed from firewall policies during a revert operation from Data ONTAP® 9.0 to 8.3. Rsh is removed because it is an insecure protocol and it is by default disabled in Data ONTAP 9.0. In Data ONTAP 8.3, the presence of rsh in firewall policies after a revert operation enables rsh. To prevent this, the rsh firewall policy is removed during the operation.
- Corrective Action
Use the "system services firewall policy create" command to reenable rsh.
- Syslog Message
Rsh removed from firewall policy because of Data ONTAP revert operations. Rsh is now disabled.
- Parameters
(None).
