scsiblade.object events
Creating your file...
scsiblade.object.out.of.sync
- Severity
ERROR
- Description
This message occurs when a SAN management event receives a timeout error due to network congestion in the system and all efforts of recovery fail. The specific SAN object for which the management event is intended will be out of sync and will have different values in cache and in persistent store. Access to LUNs within the Vserver might be affected.
- Corrective Action
Contact NetApp technical support. For further information about correcting the problem, see the knowledgebase article 2017369.
- Syslog Message
A SAN management event received a timeout error due to network congestion. Management event %llu on Vserver %s left the SAN object's cache copy out of sync with information in the persistent store. Access to LUNs within the Vserver might be affected.
- Parameters
opcode (LONGINT): Operation code.
vserver (STRING): Name or UUID of the Vserver.
