sis.default events
sis.default.auto.se.enable
Severity
NOTICE
This message occurs whenever volume move is done from a non All Flash Optimized node to an All Flash Optimized node and we attempt to enable storage efficiency features and automatic offline volume efficiency.
Corrective Action
(None).
Syslog Message
Volume efficiency features will be enabled for volume %s on aggregate %s.
vvol_name (STRING): Flex volume name.
aggr_name (STRING): Aggregate name.
sis.default.auto.se.enable.fail
Severity
NOTICE
This message occurs whenever volume move is done from a non All Flash Optimized node to an All Flash Optimized node and the attempt to enable automatic offline volume efficiency failed.
Corrective Action
(None).
Syslog Message
Failed to enable automatic offline volume efficiency features for volume %s on aggregate %s.
reason (STRING): Reason for the failure.
