sis.wafliron events
sis.wafliron.required
Severity
ALERT
This message occurs when a requested SIS volume 'undo' operation fails to correct on-disk corruption and requires wafliron to be run.
Corrective Action
Start wafliron (Command Line: 'aggr wafliron start'. See 'aggr help wafliron' for help) to correct on-disk corruptions after completion of current 'sis undo' operation on the volume.
Syslog Message
SIS 'undo' command detected on-disk corruption while working on unshare request. Run wafliron for volume '%s%s' of aggregate '%s' after completion of current 'sis undo' operation on the volume. See 'aggr help wafliron' for options on running wafliron.
volume (STRING): Name of the affected volume.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
aggregate (STRING): Aggregate name containing the affected volume.
