sm.break events
sm.break EMS events occur when the "storage efficiency" feature is enabled on a destination volume due to a broken SnapMirror® relationship on an All Flash Optimized system.
sm.break.enable.se
- Severity
NOTICE
- Description
This message occurs when the "storage efficiency" feature is enabled on a destination volume due to a broken SnapMirror® relationship on an All Flash Optimized system. When the relationship breaks, the DP volume is converted to RW, and all RW volumes have the "storage efficiency" feature enabled.
- Corrective Action
(None).
- Syslog Message
"Storage efficiency" feature has been enabled on the destination volume %s due to a SnapMirror break operation.
- Parameters
dst_path (STRING): Destination FlexVol® volume name on which the "storage efficiency" feature is enabled.
