sp.notconfigured events
sp.notconfigured EMS events occur weekly to remind you to configure the Service Processor (SP).
sp.notConfigured
- Severity
ERROR
- Description
This message occurs weekly to remind you to configure the Service Processor (SP). The SP is a physical device that is incorporated into your system to provide remote access and remote management capabilities. To use the full functionality of the SP, you need to configure it first.
- Corrective Action
Use the 'system service-processor network modify' command to configure the SP. If necessary, use the 'system service-processor network show' command to obtain its MAC address. 2. Use the 'system service-processor network show' command to verify the SP network configuration. 3. Use the 'system service-processor autosupport invoke' command to verify that the SP can send AutoSupport email. Note that AutoSupport mailhosts and recipients must be properly configured in Data ONTAP® before issuing this command.
- Syslog Message
The system's Service Processor (SP) is not configured. Use the 'system service-processor network modify' command to configure it.
- Parameters
(None).
