ONTAP EMS reference
vscan.odjob events
vscan.odJob.delete.failed
Severity
ERROR
This message occurs when the system fails to delete queued Vscan On-Demand job. The system tries to delete this job internally in a situation such as when Vserver is stopped or when a Vserver is failed over to some other cluster.
Corrective Action
Run the "vserver vscan on-demand-task unschedule" command to delete the job.
Syslog Message
System failed to delete Vscan On-Demand job for the task "%s" on Vserver "%s". Reason: "%s".
taskName (STRING): Vscan On-Demand task name.
vserverName (STRING): Name of the Vserver.
failureReason (STRING): Reason for the failure.
vscan.odJob.running.deleted
Severity
NOTICE
This message occurs when the system deletes a running On-Demand job internally.
Corrective Action
(None).
Syslog Message
System deleted a running Vscan On-Demand job. Job ID "%s".
jobID (STRING): Job ID.
vscan.odJob.schedule.failed
Severity
ERROR
This message occurs when the system fails to schedule a previously requested Vscan On-Demand job. The system tries to schedule this job internally in a situation such as when a Vserver is started or when a Vserver is failed over to some other cluster.
Corrective Action
Run the "vserver vscan on-demand-task schedule" command to schedule the job.
Syslog Message
System failed to schedule Vscan On-Demand job for the task "%s" on Vserver "%s". Reason: "%s".
