ONTAP EMS reference
vsdr.clone events
vsdr.clone.cleanup.fail
Severity
ERROR
This message occurs when a clone create job fails prematurely. As result, there is a partially created clone in the cluster.
Corrective Action
Use the (privilege: diag) "debug vreport show -type volume" command to show the list of inconsistent volumes. For each of these inconsistent volumes, use the (privilege: diag) "debug vreport fix -type volume" command to resolve all of the issues. If this is a SnapMirror® or MetroCluster(tm) environment, run the "snapmirror resync" command or the "metrocluster vserver resync" command, respectively, after the inconsistencies are resolved.
Syslog Message
Clone create job failed prematurely for volume "%s" (Vserver Id %d). Reason:%s.
volume (STRING): Name of the clone volume for which the create operation failed.
vserver_id (INT): ID of the Vserver that owns the volume.
errmsg (STRING): Error message string.
vsdr.clone.splitOnSource
Severity
ERROR
This message occurs when a clone volume is split on the source Vserver in a Vserver DR setup, and a SnapMirror® transfer is initiated after this operation.
Corrective Action
Run the "volume clone split start" command to split the volume on the dp-destination Vserver. Then run the "volume delete" command to remove the volume from the dp-destination Vserver. Then run the "snapmirror resync" command on the VserverDR relationship.
Syslog Message
The volume "%s" of Vserver "%s" has been split on the source Vserver. Split the clone volume on the destination as well. After splitting, delete the volume and execute a "snapmirror resync" command.
volume_name (STRING): Volume clone that needs to be split.
vserver_name (STRING): Vserver name for which the SnapMirror transfer has been initiated.
