The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vsdr.rootvol events
Creating your file...
Your file is ready
vsdr.rootvol.has.data
- Severity
NOTICE
- Description
This message occurs when the system detects that there is data in the Server Virtual Machine root volume during a disaster recovery (DR) transfer phase. Vserver DR does not protect root volumes.
- Corrective Action
Move the data to a nonroot volume of the Vserver if it needs to be protected using DR.
- Syslog Message
Vserver %s has data in the root volume. Vserver DR does not protect data in the root volume.
- Parameters
vserver (STRING): Name of the Vserver.
