ONTAP EMS reference
vserver.rename events
vserver.rename.fail.peer
Severity
ERROR
This message occurs when the "vserver rename" command fails to update the peer Vserver name on the peer cluster in a Vserver peer relationship.
Corrective Action
Use the (privilege: advanced) "vserver peer repair-peer-name" command in the local cluster to update the peer Vserver name in the Vserver peer relationships present on the peer cluster.
Syslog Message
Failed to update new peer Vserver %s name on peer cluster %s.
vserver_name (STRING): Vserver name that caused the update attempt to fail.
peer_cluster (STRING): Peer cluster name.
