wafl.blkreclaim events
wafl.blkreclaim EMS events occur when ONTAP encounters issues associated with block reclamation scanner operations.
wafl.blkreclaim.abort
- Severity
INFORMATIONAL
- Description
This message occurs to inform you that the block reclamation scanner was aborted.
- Corrective Action
You can disable this message as follows: setflag wafl_blk_reclaim_scan_log 0
- Syslog Message
Block reclamation scanner was aborted on %s %s%s%s%s.
- Parameters
type (STRING): Type of object (volume/aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume when the volume name alone is insufficient.
wafl.blkreclaim.complete
- Severity
INFORMATIONAL
- Description
This message occurs when the block reclamation scanner is complete.
- Corrective Action
Disable this message by running the 'setflag wafl_blk_reclaim_scan_log 0' command.
- Syslog Message
Block reclamation scanner was completed on %s %s%s%s%s. The scanner took %ld ms.
- Parameters
type (STRING): Type of object (volume or aggregate).
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
run_time (LONGINT): Total run time of the scanner.
wafl.blkreclaim.noscan
- Severity
INFORMATIONAL
- Description
This event is issued to inform the user that the block reclamation scanner was not started.
- Corrective Action
This message may be disabled with: setflag wafl_blk_reclaim_scan_log 0
- Syslog Message
Block reclamation scanner not started on %s %s%s%s%s.
- Parameters
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.blkreclaim.reset
- Severity
INFORMATIONAL
- Description
This message occurs to inform you that the block reclamation scanner was reset.
- Corrective Action
- Syslog Message
Block reclamation scanner was reset on %s %s%s%s%s.
- Parameters
