wafl.ca events
wafl.ca EMS events occur when ONTAP encounters issues associated with FabricPool capacity tier operations and object storage.
wafl.ca.cap.tier.usage.limit
- Severity
ERROR
- Description
This message occurs when the space used in the capacity tier of a FabricPool aggregate has exceeded or is projected to exceed the size limit set on the capacity tier. The projected usage is calculated based on the cold data already identified for tiering. The system will continue to serve data while space exists in the performance tier, but cold data will not be tiered to the capacity tier.
- Corrective Action
Perform one or more of the following actions: o Free space in the capacity tier of the aggregate by moving volumes, removing volumes, or deleting data. o Increase the size limit set on the capacity tier.
- Syslog Message
Aggregate %s capacity tier usage (%llu MB) has exceeded its size limit (%llu MB).
- Parameters
aggregate (STRING): Aggregate name.
capacityTierUsage (LONGINT): Current capacity tier usage in MB.
capacityTierSizeLimit (LONGINT): Capacity tier size limit in MB.
wafl.ca.cloud.retrieval.policy
- Severity
NOTICE
- Description
This message occurs when the cloud retrieval policy for a volume in a FabricPool has been modified.
- Corrective Action
(None).
- Syslog Message
Cloud retrieval policy on volume '%s%s%s%s' has been modified to %s.
- Parameters
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Identifier of the volume.
cloud_retrieval_policy (STRING): Cloud retrieval policy configured on the volume.
wafl.ca.cs.hdr.cfg.mismatch
- Severity
ALERT
- Description
This message occurs when the system detects that the IDs recorded in the configuration map for FabricPool object stores for a specific aggregate do not match the configuration IDs currently in use by the aggregate itself. This mismatch might affect the reporting of statistics and counters for FabricPool object stores.
- Corrective Action
Run the "aggr wafliron start <aggr_name>" command on the aggregate specified to fix the inconsistency.
- Syslog Message
Aggregate "%s" with bin ID "%d" has configuration IDs in the FabricPool statistics file (configuration ID 1: %d, configuration ID 2: %d) that are different from the configuration IDs of the object stores in the configuration map (primary configuration ID: %d, mirror configuration ID: %d).
- Parameters
aggr (STRING): Name of the aggregate.
bin (INT): Bin ID of the object stores.
cfg_id_1 (INT): Configuration ID 1, as reported by the aggregate.
cfg_id_2 (INT): Configuration ID 2, as reported by the aggregate.
primary_cfg_id (INT): Configuration ID of the primary object store.
mirror_cfg_id (INT): Non-zero configuration ID of the mirror object store, or zero if no such store exists.
wafl.ca.latency.threshold
- Severity
NOTICE
- Description
This message occurs when the measured I/O latency from a cloud provider, for a specific aggregate and object store, exceeds the maximum threshold. This can impact performance and lead to request timeouts.
- Corrective Action
(None).
- Syslog Message
Measured latency from cloud (%d msec) more than threshold (%d msec) (aggregate: "%s", aggregate uuid: "%s", object store: "%s")
- Parameters
latency_msec (INT): Latency cycles specified in milliseconds.
threshold_msec (INT): Threshold value in milliseconds for the latency.
aggr (STRING): Name of the containing aggregate.
aggr_uuid (STRING): UUID of the aggregate.
config_name (STRING): Object store configuration name.
wafl.ca.mcc.tlog.drain.event
- Severity
NOTICE
- Description
This message occurs when tiering is enabled or disabled on a FabricPool in a MetroCluster(tm) configuration, when one or more mirrored plexes transitions from normal to degraded state or vice versa. Enabling or disabling tiering does not impact data availability or client read/write performance.
- Corrective Action
(None).
- Syslog Message
Mirrored plex "%s" on FabricPool "%s" is in "%s" state. Tiering is %s.
- Parameters
plex_name (STRING): Name of the plex.
aggregate_name (STRING): Name of the FabricPool.
plex_state (STRING): Operational state of the plex.
message (STRING): Indicates whether tiering is enabled or disabled.
wafl.ca.migrate.aggr.nospace
- Severity
NOTICE
- Description
This message occurs when one or more FabricPool aggregates does not have space for hot data to be migrated back to the performance tier.
- Corrective Action
Either free space in the performance tier of the aggregate (by moving volumes, removing volumes, or deleting data), or add space to the performance tier of the aggregate by adding disks.
- Syslog Message
Aggregate %s: Current available space in the performance tier is below %d%%. Data migration from the capacity tier to the performance tier is stopped.
- Parameters
aggr (STRING): Aggregate name.
threshold_percentage (INT): Percentage of aggregate space that must be unused for migration to occur.
wafl.ca.name.fmt.mismatch
- Severity
ERROR
- Description
This message occurs when the system detects an internal discrepancy on the name format version used by the FabricPool. Cloud operations on the FabricPool is affected.
- Corrective Action
Run the 'debug vreport show' command to see the object name format version discrepancy. Follow the vreport guidance to fix the issue.
- Syslog Message
Name format version discrepancy detected for FabricPool "%s". Operations to the object store affected.
- Parameters
aggr (STRING): Name of the FabricPool.
wafl.ca.object.check.done
- Severity
INFORMATIONAL
- Description
This event is issued to indicate that the object check operation on a FabricPool aggregate completed successfully.
- Corrective Action
(None).
- Syslog Message
Object check operation completed on FabricPool %s. Total lost objects: %d.
- Parameters
num_lost_objs (INT): Number of lost objects identified.
wafl.ca.object.check.start
- Severity
INFORMATIONAL
- Description
This message occurs when object check operation on a FabricPool aggregate is started successfully.
- Corrective Action
(None).
- Syslog Message
Object check operation was started on FabricPool %s. Output will be saved at %s.
- Parameters
logfile (STRING): Path for the logfile for object check output.
wafl.ca.objtag.retry.limit
- Severity
NOTICE
- Description
This message occurs when the object tagging scanner fails to update tags on an object in the object store even after retrying for the maximum allowed attempts. The scanner is aborted for the current scan and will attempt to tag the object again the next time the scanner runs. The scanner is invoked every minute to check whether there are objects to be tagged.
- Corrective Action
(None).
- Syslog Message
Failed to update object tags in the object store even after multiple retry attempts, aggregate = %s, object ID =%lu, object name =%s, retries attempted = %d.
- Parameters
aggregate_name (STRING): Aggregate name.
object_id (LONGINT): Object ID.
object_name (STRING): Object name.
num_retries (INT): Number of retries attempted.
wafl.ca.objtag.skip.retry
- Severity
NOTICE
- Description
This message occurs when the object tagging scanner fails to update tags on an object in the object store even after retrying for the maximum allowed attempts. The scanner continues to update tags on other objects instead of aborting the scan due to repeated failures over one or more objects.
- Corrective Action
(None).
- Syslog Message
Failed to update object tags in the object store even after multiple retry attempts. Tagging skipped on object: aggregate = %s, object ID =%lu, object name =%s, retries attempted = %d.
- Parameters
wafl.ca.objtag.unsupported
- Severity
NOTICE
- Description
This message occurs when object tags are added or updated on a FabricPool volume. This message indicates that objects tiered from this volume will not be tagged in the object store.
- Corrective Action
(None).
- Syslog Message
Object tagging is supported only for a StorageGRID® object store in this version of ONTAP® software. Objects in %s object store (%s) attached to FabricPool %s will not be tagged in this version.
- Parameters
provider_name (STRING): Object store name.
object_store_type (STRING): Object store type (primary or mirror).
aggregate (STRING): Name of the FabricPool.
wafl.ca.promote.none.nospc
- Severity
NOTICE
- Description
This message occurs when a FabricPool volume with tiering policy set to "none" and cloud retrieve policy set to "promote" does not have enough free space available to fetch all the data from the cloud. The scanner to fetch the data will abort and be periodically rescheduled until the space is available.
- Corrective Action
Ensure the aggregate has the estimated amount of space needed available.
- Syslog Message
Aggregate %s, Volume %s: Current available space in the performance tier is %llu bytes. There needs to be at least %llu bytes free in the aggregate to fetch an estimated %llu bytes from the cloud. Data migration from the capacity tier to the performance tier is paused.
- Parameters
vol (STRING): Volume name.
avail_space (LONGINT): Free space in aggregate.
space_needed (LONGINT): Estimated amount of physical space that must be free to accommodate data fetched from the cloud.
cloud_space_to_fetch (LONGINT): Estimated amount of physical space to fetch from the cloud.
wafl.ca.promote.snap.nospc
- Severity
NOTICE
- Description
This message occurs when a FabricPool volume with tiering policy set to "snapshot_only" and cloud retrieve policy set to "promote" does not have enough free space available to fetch the AFS data from the cloud. The scanner to fetch the data will abort and be periodically rescheduled until the space is available.
- Corrective Action
- Syslog Message
Aggregate %s, Volume %s: Current available space in the performance tier is %llu bytes. There needs to be at least %llu bytes free in the aggregate to fetch AFS data from the cloud. Data migration from the capacity tier to the performance tier is paused.
- Parameters
space_needed (LONGINT): Minimum amount of physical space that must be free to accommodate AFS data fetched from the cloud.
wafl.ca.remove.object.tag
- Severity
NOTICE
- Description
This message occurs when the system encounters a bad header in the block that stores the tag values associated with the objects that belong to the volume. As a result of this corruption, all the tags information stored in the block is cleared.
- Corrective Action
(None).
- Syslog Message
Clearing all tags due to inconsistencies found in the object tag metafile associated with volume %s.
- Parameters
volname (STRING): Volume name.
wafl.ca.repaired.metafile
- Severity
ERROR
- Description
This message occurs when an inconsistency is discovered in one of the FabricPool metafile blocks. The inconsistency is automatically repaired upon detection.
- Corrective Action
(None).
- Syslog Message
Inconsistent block (%s) found in %s metafile on FabricPool aggregate (%s). Repaired.
- Parameters
state (STRING): A description of the metafile block that was found to be inconsistent.
metafile_name (STRING): Name of the metafile.
aggr (STRING): Name of the FabricPool aggregate.
wafl.ca.resync.complete
- Severity
NOTICE
- Description
This message occurs when Data ONTAP® completes the resync process from the primary object store to the mirror object store for a mirrored FabricPool aggregate.
- Corrective Action
(None).
- Syslog Message
FabricPool mirror resync process is completed for FabricPool %s (uuid %s) from primary object store (config id %u) to mirror object store (config id %u).
- Parameters
aggr_uuid (STRING): Universal Unique ID (UUID) of the aggregate.
primary_config_id (INT): Primary object store config id.
mirror_config_id (INT): Mirror object store config id.
wafl.ca.resync.read.fail
- Severity
ALERT
- Description
This message occurs when FabricPool mirror resynchronize attempt receives too many consecutive timeout failures while reading a single object from the primary. The mirror will stay in a degraded state until all objects can be read and copied to the mirror.
- Corrective Action
Verify that your intercluster LIF is online and functional by using the "network interface show" command. Also, check network connectivity to the object store server by using the "ping" command over the destination node intercluster LIF. Additionally, ensure that the configuration of your object store has not changed, and that login and connectivity information is still accurate. If the condition persists, contact NetApp technical support.
- Syslog Message
Unable to read cloud object from capacity tier (objid %llu, btuuid %s, seqno %llu) during FabricPool mirror resync.
- Parameters
object_id (LONGINT): Object identifier.
btuuid (STRING): Buftree UUID.
seqno (LONGINT): Sequence number.
wafl.ca.resync.read.set.err.obj
- Severity
ALERT
- Description
This message occurs when Data ONTAP® marks all blocks in an object in a capacity tier object with an error due to FabricPool mirror resync read errors. This is useful for tracking generation of some pseudobad blocks due to resync read issues.
- Corrective Action
Contact Contact NetApp technical support..
- Syslog Message
Unable to read cloud object from capacity tier (objid %llu, btuuid %s, seqno %llu) during FabricPool mirror resync. As a result, all blocks in this object are marked with error (%u).
- Parameters
error (INT): Error on the block.
wafl.ca.revert.ufmt.paused
- Severity
ERROR
- Description
This message occurs when the revert operation to convert a unified object format is paused either because there are one or more offline volumes in the FabricPool aggregate or because the tiering of unified format objects to the object store is pending.
- Corrective Action
Bring the volumes online in the aggregate to resume the unified object format revert operation. Use the "volume object-store tiering show" command to check the tiering status of a volume.
- Syslog Message
The operation to revert the object format to the native format paused on aggregate "%s" because there are offline volumes or the tiering of unified format objects to the object store is pending.
- Parameters
wafl.ca.slothdr.repair.done
- Severity
INFORMATIONAL
- Description
This event is issued to indicate that the slothdr repair operation for a FabricPool aggregate completed successfully.
- Corrective Action
(None).
- Syslog Message
Slothdr metafile repair operation completed for FabricPool %s.
- Parameters
wafl.ca.slothdr.repair.start
- Severity
INFORMATIONAL
- Description
This message occurs when an operation to repair the slothdr metafile for a FabricPool aggregate is started successfully.
- Corrective Action
(None).
- Syslog Message
Slothdr metafile repair operation was started for FabricPool %s.
- Parameters
wafl.ca.tier.aggr.spc.limit
- Severity
ERROR
- Description
This message occurs when the FabricPool aggregate does not have enough free space to tier cold data to the capacity tier. The system will continue to serve data, but cold data will not be tiered.
- Corrective Action
Either free space in the performance tier of the aggregate by moving volumes, removing volumes, or deleting data, or add space to the performance tier of the aggregate by adding disks.
- Syslog Message
Aggregate %s: Current available space in the performance tier is below %d%%. Data tiering from the performance tier is stopped.
- Parameters
threshold_percentage (INT): Percentage of aggregate space that must be unused for tiering to occur.
wafl.ca.tier.max.size.limit
- Severity
ERROR
- Description
This message occurs when the capacity tier of a FabricPool aggregate reaches the maximum supported capacity tier size. The system will continue to serve data, but cold data will not be migrated to the capacity tier.
- Corrective Action
This state can be corrected by performing one or more of the following actions: o Free space in the capacity tier of the aggregate by moving volumes, removing volumes, or deleting data.
- Syslog Message
Aggregate %s capacity tier usage (%llu MB) has reached the maximum capacity tier size limit (%llu MB).
- Parameters
maxCapacityTierSizeLimit (LONGINT): Maximum capacity tier size in MB.
wafl.ca.tiering.policy
- Severity
NOTICE
- Description
This message occurs when the tiering policy for a volume in a FabricPool has been modified.
- Corrective Action
(None).
- Syslog Message
Tiering policy on volume '%s%s%s%s' has been modified to %s.
- Parameters
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
tiering_policy (STRING): Tiering policy configured on the volume.
wafl.ca.tlogput.modified
- Severity
INFORMATIONAL
- Description
This message occurs when the tlog_put command was used to modify FabricPool PUT operation settings.
- Corrective Action
(None).
- Syslog Message
The FabricPool tlog_put command was used to modify Put operation settings. New Values, bytes_limit: %llu, preserved: %u,%u
- Parameters
bytes_limit (LONGINT): The bytes_limit value.
preserve (INT): The preserve setting value.
can_preserve (INT): Non-Zero if the node supports preserving settings.
wafl.ca.total.space.incons
- Severity
ERROR
- Description
This message occurs when the counter tracking the total amount of space used in an object store bucket becomes inconsistent due to other inconsistencies in the object metadata.
- Corrective Action
For more information or assistance, contact NetApp technical support.
- Syslog Message
Inconsistency was found in the total object store space used by FabricPool aggregate "%s". Skipped space adjustments have caused overcounting by as much as %llu bytes.
- Parameters
aggrname (STRING): Name of the aggregate.
space_delta (LONGINT): The estimated amount of space in bytes that could be overcounted as a result of other inconsistencies.
