The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
wafl.data events
Creating your file...
Your file is ready
wafl.data.compaction.event
- Severity
NOTICE
- Description
This message occurs when data compaction functionality is enabled or disabled on a volume.
- Corrective Action
(None).
- Syslog Message
WAFL volume data compaction state changed in %s "%s" to "%s".
- Parameters
volume_identifier (STRING): Volume identifier.
volume (STRING): Volume name.
message (STRING): Whether enable or disable.
