ONTAP EMS reference
wafl.fc events
wafl.fc EMS events occur when a FlexCache® origin node detects that its FlexCache volume has disconnected while a lock reclaim operation is in progress.
wafl.fc.recl.csm.disconnect
Severity
EMERGENCY
This message occurs when a FlexCache® origin node detects that its FlexCache volume has disconnected while a lock reclaim operation is in progress.
Corrective Action
Verify that the intercluster LIFs on both nodes are operational.
Syslog Message
FlexCache origin node with UUID %s detected potential disconnect with FlexCache with UUID %s while processing lock reclaims for the volume with MSID %u hosted on Vserver with UUID %s.
localbladeuuid (STRING): Universally unique identifier (UUID) of the origin node.
bladeuuid (STRING): UUID of the FlexCache Cache node.
msid (LONGINT): Volume master data set identifier (MSID) of the FlexCache volume.
vserveruuid (STRING): UUID of the FlexCache Vserver.
