wafl.gs events
wafl.gs.metafile.load.failed
Severity
ERROR
This message occurs when wafl is unsuccessful to check and load Granular Set metafile for the volume.
Corrective Action
Issue volume offline followed by volume online and confirm this error message does not happen again. For more information or assistance, contact NetApp technical support.
Syslog Message
Wafl failed to load metafile that stores wafl copy of SnapMirror CG.
volume (STRING): Volume name.
error (INT): Error code.
wafl.gs.modify.op.failed
Severity
NOTICE
This message occurs when WAFL® prohibits loading a file for a modify operation on a read-only consistency group.
Corrective Action
NONE.
Syslog Message
Failed to load file ID %u on volume %s%s%s%s FSID:%u for a modify operation because it is part of a read-only sync relationship.
fileid (INT): File identifier.
volowner (STRING): Owner of the volume.
volname (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient. Consists of the Vserver name and UUID.
fsid (INT): File system ID of the volume.
wafl.gs.remove.rename.op.failed
Severity
NOTICE
This message occurs when WAFL® prohibits a rename operation or an unlink operation on a file part of a consistency group.
Corrective Action
NONE.
Syslog Message
Failed to load file ID %u on volume %s%s%s%s FSID:%u for a rename operation or an unlink operation because it is part of a sync relationship.
wafl.gs.resync.gen.check.failed
Severity
NOTICE
This message occurs when WAFL® prohibits modification to a file that is part of a consistency group and the operation does not have the right generation enforcement parameters. This can occur if the operation happened before the SnapMirror® relationship was established.
Corrective Action
NONE.
Syslog Message
Unexpected operation on consistency group file ID %u on volume %s%s%s%s FSID:%u. This can occur if the operation happened before the SnapMirror relationship was established.
