wafl.reallocate events
wafl.reallocate.aggr.interrupt
Severity
INFORMATIONAL
This message occurs when an aggregate reallocation scan is interrupted. The scan was scheduled using the 'reallocate -A' command.
Corrective Action
None required.
Syslog Message
Aggregate reallocation scan on '%s' was interrupted.
path (STRING): Scan path.
wafl.reallocate.check.high
Severity
INFORMATIONAL
This event is issued if an allocation check scan (issued before reallocation starts) returns indicating that the path requires reallocation.
Corrective Action
None required. The reallocation scan will automatically be started.
Syslog Message
Allocation check on '%s' is %d, hotspot %d (threshold %d), so will reallocate.
path (STRING): The scan path
optim (INT): The current optimization of the path
hot_spot (INT): The current hot-spot optimization of the path
threshold (INT): The reallocation threshold of the path
wafl.reallocate.check.highAdvise
Severity
INFORMATIONAL
This event is issued if an allocation check scan returns indicating that the path would benefit from reallocation.
Corrective Action
Consider reallocating the path (see na_reallocate(1))
Syslog Message
Allocation check on '%s' is %d, hotspot %d (threshold %d), consider running reallocate.
wafl.reallocate.check.value
Severity
INFORMATIONAL
This event is issued to report the optimization of a path.
Corrective Action
None required.
Syslog Message
Allocation measurement check on '%s' is %d.
optim (INT): The path optimization.
wafl.reallocate.full.done
Severity
INFORMATIONAL
This event is issued to report the completion of a full, one-time, reallocation scan.
Corrective Action
None required.
Syslog Message
Full reallocation on '%s' is complete.
wafl.reallocate.full.interrupt
Severity
INFORMATIONAL
This event is issued to report that a full, one-time, reallocation scan was interrupted.
Corrective Action
None required.
Syslog Message
Full reallocation on '%s' was interrupted.
wafl.reallocate.path.invalid
Severity
ERROR
This event is issued if an invalid scan path is detected.
Corrective Action
Check why the scan path is invalid, including file removal or volume offline. If the condition is persistent remove the associated reallocation scan.
Syslog Message
Unavailable/invalid reallocation path '%s' detected.
wafl.reallocate.recheck.ok
Severity
INFORMATIONAL
This event is issued if an allocation recheck scan (issued after reallocation has completed) returns indicating the optimization is under the threshold.
Corrective Action
None required.
Syslog Message
Allocation check on '%s' is under threshold.
wafl.reallocate.scan.exists
Severity
INFORMATIONAL
This event is issued if an attempt is made to add a new reallocation scan but a scan job already exists for the supplied path.
Corrective Action
Check the path is correct. If it is correct then delete the previous reallocation job, and add a new one. Use the 'reallocate status' command to list reallocation jobs.
Syslog Message
A reallocation scan for %s already exists.
path (STRING): The path with the scan.
wafl.reallocate.scan.noStart
Severity
NOTICE
Reallocation tasks, such as measuring the layout of a file or performing block reallocation, may be perfomed using an asynchronous WAFL scanner. This event is issued if an error occurs unexpectedly while trying to start such a WAFL scanner.
Corrective Action
(Call support).
Syslog Message
reallocate: unable to start '%s' scanner for '%s': %d (%s)
scan_type (STRING): The type of scan operation.
path (STRING): The scan path or aggregate name.
err_code (INT): A numerical error code indicating the reason why the scanner could not be started.
err_string (STRING): A string interpreting the err_code.
wafl.reallocate.scan.remove
Severity
INFORMATIONAL
This event is issued when a reallocation job is persistently removed from the system.
Corrective Action
None required.
Syslog Message
Reallocation scan for '%s' is being removed.
wafl.reallocate.schedule.invalid
Severity
ERROR
This event is issued if an invalid reallocation schedule is detected.
Corrective Action
Correct the schedule syntax then retry the operation
Syslog Message
Invalid schedule: %s
reason (STRING): The reason why the schedule is invalid
