wafl.root events
wafl.root.autocreate
Severity
NOTICE
This event is issued when no online root volume is found. It is used to indicate that auto creation of a root volume will happen.
Corrective Action
(None).
Syslog Message
No online root volume found on root aggregate %s. Automatically creating one.
aggr (STRING): The root aggregate name
wafl.root.content.changed
Severity
ERROR
This message occurs when the contents of the root volume are changed to those of a previous point in time. One of the following operations or events can cause the contents of the root volume to change: - The root volume is changed from the boot menu. - The nvlog is jettisoned. - The system is booted with prev_cp. - The 'wafliron -prev_cp' command is used and the changes are commited. - A SnapRestore® operation is done on the root volume.
Corrective Action
Verify that all recent configuration changes are still in effect.
Syslog Message
Contents of the root volume '%s' might have changed. Verify that all recent configuration changes are still in effect.
vol (STRING): Name of the root volume.
wafl.root.create
Severity
INFORMATIONAL
This message occurs when the system creates a root volume.
Corrective Action
(None).
Syslog Message
New root volume %s created.
wafl.root.mark.error
Severity
NOTICE
This event is issued when there is an error in syncing the vvol raid label of a newly created root volume.
Corrective Action
(None).
Syslog Message
Error setting volume %s%s as root. Changes may not be saved.
vol (STRING): The root volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.root.overwritesUnsafe
Severity
ERROR
This message occurs when the root volume is not volume guaranteed or does not guarantee overwrites for space reserved files.
Corrective Action
Set the Space Guarantee on the root volume to "volume" and the Fractional Reserve on the root volume to 100%.
Syslog Message
Root volume %s does not protect overwrites in space reserved files.
vol (STRING): Root volume name.
