wafl.sfsr events
wafl.sfsr.abort.ino
Severity
NOTICE
This event is issued when the system is forced to abort a file restore.
Corrective Action
(None).
Syslog Message
Single-file snaprestore of inode %u (snapid %d, %s %s%s%s%s) to inode %u prematurely halted.
srcIno (INT): The source inode number
snapId (INT): The snapshot identifier
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
dstIno (INT): The target inode number
wafl.sfsr.abort.inoDeleted
Severity
NOTICE
This event is issued when the system is forced to abort a file restore. The inode was deleted.
Corrective Action
(None).
Syslog Message
Single-file snaprestore of inode %u (snapid %d, %s %s%s%s%s) to inode %u aborted. File was deleted.
wafl.sfsr.done
Severity
INFORMATIONAL
This message occurs when a file restore operation has completed.
Corrective Action
(None).
Syslog Message
Single-file snaprestore of inode %u (snapid %d, %s %s%s%s%s) to inode %u has completed.
srcIno (INT): Source inode number.
snapId (INT): Snapshot™ identifier.
type (STRING): Type of object (volume/aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
dstIno (INT): Target inode number.
wafl.sfsr.lun.error
Severity
ERROR
This message occurs when the system attempts to restore a file onto a LUN. This is not a supported action; files cannot be restored onto a LUN.
Corrective Action
No corrective action is possible; files cannot be restored onto a LUN.
Syslog Message
Attempted to restore a file onto a LUN, but files cannot be restored onto a LUN. (vol='%s', volident='%s', snapname='%s', filename='%s')
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
snapname (STRING): Name of the Snapshot(tm) copy that the file is being restored from.
filename (STRING): Name of the file that cannot be restored onto a LUN.
wafl.sfsr.lun.name.error
Severity
ERROR
This event is issued when a LUN is being restored to a new location and the path to the new location contains invalid characters. The valid characters for the last component in the lun path are A-Z, a-z, 0-9, '-', '.', '_', '{' and '}'.
Corrective Action
Make sure that the last component of the path to the new location contains characters from A-Z, a-z, 0-9, '-', '.', '_', '{' and '}'.
Syslog Message
Can't restore LUN due to invalid restore path. The last component of the restore path can only contain characters from A-Z, a-z, 0-9, '-', '.', '_', '{' and '}'.
(None).
wafl.sfsr.lun.restore.error
Severity
ERROR
This message occurs when the system attempts to restore a LUN to something other than qtree root. This is not a supported action; LUNs can only be restored into qtree roots.
Corrective Action
No corrective action is possible; LUNs can only be restored into qtree roots.
Syslog Message
Attempted to restore a LUN to something other than a qtree root, but LUNs can only be restored into qtree roots. (vol='%s', volident='%s', snapname='%s', filename='%s')
snapname (STRING): Name of the Snapshot(tm) copy that the LUN is being restored from.
filename (STRING): Name of the file that the LUN is being restored from.
wafl.sfsr.quota.error
Severity
ERROR
This message occurs when the system cannot restore a file because doing so would exceed quotas.
Corrective Action
Modify the quotas on the volume or qtree being restored into to accommodate the file, and then try the restore again.
Syslog Message
File cannot be restored because doing so would exceed quotas. (vol='%s', volident='%s')
wafl.sfsr.sr.disabled
Severity
ERROR
This event is generated when a single-file snap restore (sfsr) operation on a file with a space reservation fails because there is not enough space on the volume to restore the file with its space reservation. If there was room for the file without a space reservation, then the file was restored with its space reservation disabled.
Corrective Action
If this event happened because the single-file snaprestore (sfsr) failed then space on the volume must be freed and the sfsr redone. If the sfsr was otherwise successful then space on the volume must be freed and reservations re-enabled by using "file reservation file-path enable".
Syslog Message
Single-file snaprestore of inode %u on %s %s%s%s) did not restore space reservations due to lack of disk space.
