ONTAP EMS reference
wafl.volume events
wafl.volume EMS events occur when ONTAP encounters issues associated with volume configuration and management.
wafl.volume.charmap.loadfail
Severity
ERROR
This message occurs when a volume comes online with a corrupted or unavailable character mapping configuration.
Corrective Action
Remove character mapping by using the "vserver cifs character-mapping delete" command. Then reapply it by using the "vserver cifs character-mapping create" command. For more information, see the "vserver cifs character-mapping" man page. For further assistance, contact NetApp technical support.
Syslog Message
Failed to load character mapping configuration for volume %s. Reason: %s.
volname (STRING): Volume for which loading of the character mapping configuration failed.
reason (STRING): Reason for failure.
wafl.volume.clone.created
Severity
INFORMATIONAL
This message occurs when a clone of a flexible volume is created successfully.
Corrective Action
(None).
Syslog Message
Volume clone %s of volume %s was created successfully.
clonename (STRING): Volume clone name
volname (STRING): Volume name
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
wafl.volume.clone.fractional_rsrv.changed
Severity
INFORMATIONAL
This message occurs when the space reservation of a flexible volume clone is changed to 100 percent because guarantee of the clone is set to 'file'.
Corrective Action
(None).
Syslog Message
Fractional reservation for clone '%s:%d' was changed to 100 percent because guarantee is set to 'file'.
clonename (STRING): Volume clone name.
Ordinal (INT): Volume Ordinal.
wafl.volume.clone.snap.cpcount.load.failure
Severity
ERROR
This message occurs when a clone of a flexible volume fails to load the cp count of its or the parent volume's base snapshots.
Corrective Action
(None).
Syslog Message
Volume clone %s failed to load the cp count of its or the parent volume's base snapshot, with Snap ID %d.
snapid (INT): Snapshot ID of the clone volume's base snapshot.
wafl.volume.clone.split.started
Severity
INFORMATIONAL
This message occurs when an operation to split a flexible volume clone from its parent volume is started successfully.
Corrective Action
(None).
Syslog Message
Clone split was started for volume %s%s%s
wafl.volume.clone.with.uid.gid
Severity
INFORMATIONAL
This message occurs when a clone of a flexible volume is created with a volume-level UID and GID.
Corrective Action
Split the clone volume before creating this as a source of an XDP-type SnapMirror relationship.
Syslog Message
Volume clone %s%s%s was created with vol-level UID and GID. If this clone volume is used as a source of XDP type SnapMirror relationship, then UID and GID of all the transferred file at the destination will be unpredictable.
vserver_uuid (STRING): Universal Unique ID (UUID) of the clone volume's Vserver.
wafl.volume.inuse
Severity
ALERT
This message occurs when a volume operation fails because the volume is being used in another operation.
Corrective Action
Check the status of the volume and aggregate using the "vol show" and "aggr show" commands. If there are no other operations running on either of them then retry your request. If problems persists, or you need further assistance, contact NetApp technical support.
Syslog Message
%s %s %s operation failed as volume is busy in another operation.
type (STRING): Type of object (volume or aggregate).
vol (STRING): Name of the volume.
operation (STRING): Operation.
wafl.volume.inuse.by
Severity
ALERT
This message occurs when a volume operation fails because the volume or parent aggregate is being used by another operation.
Corrective Action
Check the status of the volume and aggregate. Wait for the current operation to finish, and then retry your request. If problems persist or you need further assistance, contact NetApp technical support.
Syslog Message
%s %s %s operation failed because the volume or parent aggregate is locked by operation %s.
operation (STRING): Operation that failed.
locked_by (STRING): Operation currently locking the volume or parent aggregate.
wafl.volume.sidl.enableErr
Severity
ERROR
This message occurs when an attempt to enable Single Instance Data Logging (SIDL) on a volume fails.
Corrective Action
Use the "volume efficiency show" and "volume show" commands to check the volume for enabled features that are incompatible with SIDL, such as compaction or inline deduplication. After the incompatible features are disabled, wait 10 seconds and then enable SIDL again.
Syslog Message
SIDL was not enabled on volume %s
volume (STRING): Volume name.
wafl.volume.sidl.offline
Severity
ERROR
This message occurs when a volume with single instance data logging enabled is taken offline due to the current version of Data ONTAP not supporting that feature. This situation can occur if a volume with the feature enabled is attempted to be onlined using a version of Data ONTAP that doesn't support it.
Corrective Action
To bring the volume online, use a version of Data ONTAP that supports single instance data logging.
Syslog Message
Volume "%s" was taken offline because the current version of Data ONTAP does not support single instance data logging, an enabled feature on this volume.
wafl.volume.slag.loadfailed
Severity
ERROR
This message occurs when a loading or update of Storage-Level Access Guard(SLAG) fails because of an internal error. In this case, SLAG is not activated on the volume or qtree.
Corrective Action
Remove SLAG by using the "vserver security file-directory remove-slag" command, and then reapply it by using the "vserver security file-directory apply" command.
Syslog Message
Failed to load or update SLAG for SLAG level: %d on qtree ID: %d in volume "%s%s%s%s". Error:%d Reason: %s.
loadflag (INT): SLAG load flag.
qtree (INT): Qtree identifier.
owner (STRING): Owner of the volume.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
waflerror (INT): WAFL error which caused the failure.
reason (STRING): Reason for the failure.
wafl.volume.snap.autoDelete
Severity
INFORMATIONAL
This message occurs when a Snapshot(tm) copy in the volume is being deleted to free space. Snapshot copies can be deleted automatically from a volume to enforce the corresponding automatic deletion policy.
Corrective Action
(None).
Syslog Message
Deleting Snapshot copy '%s' in volume '%s%s%s' to recover storage.
name (STRING): Snapshot copy name.
vol (STRING): Volume name.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
