ONTAP EMS reference
audit.log events
audit.log EMS events occur when ONTAP encounters issues associated with message auditing, log file management, and queue operations.
audit.log.event
Severity
NOTICE
This message occurs when there is an issue during message auditing. The system recovers by itself.
Corrective Action
(None).
Syslog Message
Auditing error (%s) occurred at %s.
error (STRING): Error encountered during message auditing.
time (STRING): Time that this error occurred.
audit.log.file.recovered
Severity
NOTICE
This message occurs when the system recovers a previously deleted log file as part of audit log policy.
Corrective Action
(None).
Syslog Message
Recovered previously deleted audit log file "%s".
log_name (STRING): Log file name.
recovered_time (STRING): File recovery timestamp.
audit.log.queue.high
Severity
NOTICE
This message occurs when the syslog queue reaches 75% of its maximum size.
Corrective Action
Verify remote server network reachability and processing performance.
Syslog Message
Log queue for destination %s, protocol %s has exceeded 75%% of capacity. Last audit log was sent successfully at %s, number of pending messages: %d.
syslog_dest (STRING): Log forwarding destination for which messages are being dropped.
protocol (STRING): Protocol used for syslog destination.
last_sent (STRING): Time that the audit log was last successfully sent to the syslog destination.
pending_msg (INT): Number of pending messages in queue.
audit.log.queue.overflow
Severity
NOTICE
This message occurs when an internal queue overflow causes the audit logging mechanism to drop messages destined for a particular log forwarding destination.
Corrective Action
Syslog Message
Log queue overflowed for destination %s, protocol %s. Current drop count: %ld.
drop_count (LONGINT): Number of messages dropped since the last drop was reported.
audit.log.queue.recovered
Severity
NOTICE
This message occurs when the audit logging queue recovers after earlier message drops, and the current queue is less than 75% full.
Corrective Action
(None).
Syslog Message
Log queue recovered for destination %s, protocol %s. Issue start time: %s, end time: %s, total number of drops during this period: %ld.
syslog_dest (STRING): Log forwarding destination for which the queue has recovered.
protocol (STRING): Protocol used for the syslog destination.
issue_start_time (STRING): Time that the queue overflowed.
recovered_time (STRING): Time that the queue recovered.
drop_count (LONGINT): Total number of drops since the last time the queue overflowed.
audit.log.rotate.size.limit
Severity
NOTICE
This message occurs when the system rotates a log file that has reached its size limit.
Corrective Action
(None).
Syslog Message
Log file %s has been rotated because size limit %ld was reached.
max_log_size (LONGINT): Maximum log file size.
