callhome.mccip events
callhome.mccip EMS events occur when ONTAP encounters issues associated with MetroCluster(tm) IP configuration.
callhome.mccip.auso.disabled
- Severity
ALERT
- Description
This message occurs when automatic unplanned switchover (AUSO) in a MetroCluster(tm) IP configuration is disabled because the mediator mailbox disk is not healthy. If a site failure occurs, a manual switchover will be required to restore data access.
- Corrective Action
Use the "storage failover show -fields local-mailbox-disks" command to verify that all nodes in the cluster can access their respective mailbox disks. Use the (privilege: advanced) "storage iscsi-initiator show" command to verify that iSCSI connections to the mediator are up and healthy.
- Syslog Message
Callhome for %s.
- Parameters
subject (STRING): AutoSupport subject or title for this event.
callhome.mccip.collectstats
- Severity
NOTICE
- Description
This message occurs when MetroCluster IP statistics are collected daily. TCP/IP networking statistics for diagnostic purposes are collected.
- Corrective Action
(None).
- Syslog Message
Call home for %s.
- Parameters
