cmds.sysconf events
cmds.sysconf.haltERR1
- Severity
ALERT
- Description
This message occurs to log the reason for system halt, before actually system is halted.
- Corrective Action
(None).
- Syslog Message
Halting system due to %d configuration problems.
- Parameters
errCount (INT): Number of error which caused the system halt.
cmds.sysconf.haltERR2
- Severity
ALERT
- Description
- Corrective Action
(None).
- Syslog Message
Halting system due to a configuration problem.
- Parameters
(None).
cmds.sysconf.inconstRule
- Severity
INFORMATIONAL
- Description
This message occurs because the rule for the card is applicable to both non_cluster_only and cluster_only systems, which is inconsistent.
- Corrective Action
(None).
- Syslog Message
Rule for model %s card %s is inconsistent: it applies both to cluster-only and non-cluster-only.
- Parameters
model (STRING): Model ID.
card (STRING): Card ID.
cmds.sysconf.logErr
- Severity
NOTICE
- Description
This message occurs to log the error through syslog as an Error or Informational message depending upon the error count which is in this case greater than 0.
- Corrective Action
(None).
- Syslog Message
%s.
- Parameters
errMsg (STRING): Error message to be logged.
cmds.sysconf.logInfo
- Severity
INFORMATIONAL
- Description
This message occurs to log the error through syslog as an Error or informational message depending upon the error count which is in this case less than or equal to 0.
- Corrective Action
(None).
- Syslog Message
%s.
- Parameters
cmds.sysconf.perIntSmall
- Severity
INFORMATIONAL
- Description
This message occurs because the value for a periodic interval for internal testing is set too small, less than the minimum allowed.
- Corrective Action
(None).
- Syslog Message
options.sysconfig.periodic_interval of %d minutes is too small; using %d.
- Parameters
valueUsed (INT): Value used for testing purpose.
defaultMinValue (INT): Minimum value allowed for a periodic interval.
cmds.sysconf.syslogger
- Severity
NOTICE
- Description
This message occurs to send the output to syslog rather than command prompt because the option '-l' with sysconfig command is not documented and is included in DEBUG builds only.
- Corrective Action
(None).
- Syslog Message
%s.
- Parameters
message (STRING): 'sysconfig -l' Command output message.
