config.mirroring events
config.mirroring EMS events occur when the name-service configuration is not replicated in the node.
config.mirroring.failure
- Severity
ERROR
- Description
This message occurs when the name-service configuration is not replicated in the node. The out-of-sync configuration file can impact access during data access attempts.
- Corrective Action
Use the "vserver services name-service unix-user load-from-uri" or "vserver services name-service unix-group load-from-uri" command to reload the configuration file. Use the (privilege: advanced) "vserver services name-service unix-user file status" or "vserver services name-service unix-group file status" command to verify that the configuration file was successfully loaded and corresponding database was successfully generated.
- Syslog Message
Failed getting the latest %s file for Vserver %s on node %s with error %s.
- Parameters
configuration (STRING): Name of the configuration.
vserver_name (STRING): Name of the vserver, for which the configuration was not successfully replicated.
node_name (STRING): Name of the node on which configuration failed to replicate.
error_string (STRING): Error encountered while extracting package.
