The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.notmultipath events
Creating your file...
Your file is ready
config.NotMultiPath
- Severity
ERROR
- Description
This message occurs when a disk is not multipathed.
- Corrective Action
Multipath the disk shelf stack by also attaching it to a different host adapter via the other shelf module in each disk shelf in the stack.
- Syslog Message
Disk %s and other disks on this loop/domain are not multipathed and should be for improved availability.
- Parameters
disk (STRING): Name of the disk.
