The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
coredump.all events
Creating your file...
Your file is ready
coredump.all.disks.used
- Severity
ERROR
- Description
All disks available to coredump already contain unsaved cores.
- Corrective Action
There are three choices. First, add more disks to the system. Second, delete any unsaved cores by running "savecore -k". Third, save any unsaved cores by running "savecore". It may be necessary to run "savecore -f" to save the cores, if previous attempts to save these cores have failed.
- Syslog Message
No disks available for dumpcore
- Parameters
(None).
