cpeer.recv events
cpeer.recv.pp.mismatch
- Severity
NOTICE
- Description
This message occurs when there is an incoming cluster peer request using the system-generated passphrase. However, the cluster peer request authentication failed due to passphrase mismatch and so the cluster peer offer is deleted.
- Corrective Action
Verify the peer request with peer cluster admin. If required, use the "cluster peer create" command with "generate-passphrase" option to generate the additional cluster peer offers.
- Syslog Message
The cluster peer offer with system-generated passphrase was attempted for cluster peering by the remote cluster (%s:%s) with address %s but cluster peer request failed due to passphrase mismatch. So, the offer is deleted.
- Parameters
remotename (STRING): Remote cluster name.
remoteuuid (STRING): Remote cluster UUID.
address (STRING): Remote cluster IP address.
