dbs.cluster events
Creating your file...
dbs.cluster
- Severity
NOTICE
- Description
This message occurs when a Distributed Block Store (DBS) event related to cluster operations occurs. If the original DBS event specifies multiple drives, then an EMS event is generated for each drive.
- Corrective Action
(None).
- Syslog Message
A DBS event occurred, event %s, type %s, service %u, node %u/%s, drive %u/%s, eventID %u.
- Parameters
evtMessage (STRING): Description of the DBS event, including context details.
evtType (STRING): Type of the original DBS event.
serviceID (INT): Service ID that identifies the associated DBS service. It is "0" if there is no associated service.
nodeID (INT): Node ID number of the associated node. It is "0" if there is no associated node.
nodeUuid (STRING): Generated Universal Unique Identifier (UUID) of the associated node. It displays zeroes if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is "0" if there is no associated drive.
driveUuid (STRING): Generated UUID of the associated drive. It displays zeroes if there is no associated drive.
evtID (INT): DBS event ID number.
evtDetails (STRING): Specific details of the DBS event. It displays as a string, in JSON format, or is empty.
dbs.cluster.iops.overprov
- Severity
ERROR
- Description
This message occurs when the distributed block store detects that the sum of all minimum quality of service (QoS) IOPS of flexible volumes is greater than the expected IOPS of the cluster. Minimum QoS cannot be maintained for all flexible volumes simultaneously. The distributed block store is responsible for managing the data that backs the flexible volumes.
- Corrective Action
Adjust QoS settings on one or more flexible volumes, or add more nodes to increase cluster IOPS capabilities.
- Syslog Message
The distributed block store detects that the sum of all minimum QoS IOPS is greater than the expected IOPS of the cluster. The cluster fault type is %s and fault id is %u.
- Parameters
cfType (STRING): Distibuted block store cluster fault type of the associated object.
cfID (INT): Distibuted block store cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): Distibuted block store cluster fault external source label created by the "CreateClusterFault" API command and attached to the fault for testing purposes.
dbs.cluster.master
- Severity
NOTICE
- Description
This message occurs when a Distributed Block Store (DBS) event related to cluster master operation occurs, such as cluster master being selected or cluster capacity limits being reached.
- Corrective Action
(None).
- Syslog Message
A DBS cluster master event %s of type %s occurred for Service ID %u on node %u/%s. Drive ID = %u/%s. Event ID = %u.
- Parameters
serviceID (INT): Service ID that identifies the associated DBS service. It is 0 if there is no associated service.
nodeID (INT): Node ID number of the associated node. It is 0 if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is 0 if there is no associated drive.
