The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
dfu.firmwaredownrev events
Creating your file...
Your file is ready
dfu.firmwareDownrev
- Severity
ERROR
- Description
This message occurs when the system finds disks with a downrev version of firmware, as defined by the installed version of Data ONTAP®.
- Corrective Action
Use the "storage disk firmware update" command to update the downrev firmware on the disks. Check your support provider for more information about obtaining the latest disk firmware. If the problem persists, contact NetApp technical support.
- Syslog Message
Downrev firmware on %d disks.
- Parameters
downrev (INT): Number of disks with downrev firmware.
