dfu.mallocfailed events
Creating your file...
Your file is ready
dfu.mallocFailed
- Severity
ALERT
- Description
This message occurs when Data ONTAP® cannot allocate memory to read the disk firmware file and aborts the disk firmware update.
- Corrective Action
Inability to allocate memory for this action indicates a failure within Data ONTAP. Take a core for reference, and then open a support case to address the underlying issue. The reboot process when you take the core resolves the immediate problem.
- Syslog Message
Cannot allocate memory to read disk firmware file %s; disk firmware update aborted.
- Parameters
filename (STRING): Name of the disk firmware file.
