dfu.readtestfailed events
Creating your file...
dfu.readTestFailed
- Severity
ERROR
- Description
This message occurs when a read of the disk fails after downloading firmware to a disk.
- Corrective Action
Disk was unable to be read from after a firmware update occurred. I/O will be retried. If the retries are not successful, you should fail the disk and return it for RMA.
- Syslog Message
Media Access test failed on Disk %s [%s %s %s] S/N [%s].
- Parameters
diskName (STRING): Name of the disk.
vendorName (STRING): Vendor name of the disk.
productId (STRING): Product ID of the disk.
fwVersion (STRING): Firmware version of the disk.
serialno (STRING): Serial number of the disk.
dfu.readTestFailed.fatal
- Severity
ERROR
- Description
This message occurs when a read of the disk fails after downloading firmware to a disk and all retries have been exhausted.
- Corrective Action
Disk was unable to be read from after a firmware update occurred. I/O will be retried. If the retries are not successful, you should fail the dise and return it for RMA.
- Syslog Message
Unable to access media after firmware update on Disk %s [%s %s %s] S/N [%s].
- Parameters
