      diskown.bayctrlr events
diskown.bayctrlr
- Severity
NOTICE
 - Description
This message occurs if the controller address is determined when the bay policy override option has been set. The controller address "A/B" is used to automatically assign the disks in odd/even bays.
 - Corrective Action
(None).
 - Syslog Message
Determined controller address %s based on shelf ID %d and slot number %d.
 - Parameters
ctrlr (STRING): Controller address.
shelfId (INT): ID of the shelf chosen to determine the controller address.
slot (INT): Slot number of the shelf chosen to determine the controller address.
diskown.bayctrlr.unknown
- Severity
NOTICE
 - Description
This message occurs when disks in a shelf are not assigned to the current node.
 - Corrective Action
(None).
 - Syslog Message
Cannot make determination of controller address.
 - Parameters
(None).
