ONTAP EMS reference
diskown.rescanmessagefailed events
diskown.rescanmessagefailed EMS events occur when a disk rescan message is sent, but does not go through while transferring the ownership of a disk to another node.The node to which the disk ownership is transferred might not detect them until it performs the rescan.
diskown.RescanMessageFailed
Severity
ERROR
This message occurs while transferring the ownership of a disk to another node, when a rescan message is sent but does not go through.
Corrective Action
Use the "disk show" command on the nodeshell of %s for the node to rescan the disks which changed ownership.
Syslog Message
Could not send rescan message to %s.
hostname (STRING): Name of the host that the message was sent to.
