The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fcvi.initfailed events
Creating your file...
Your file is ready
fcvi.initFailed
- Severity
ERROR
- Description
This message occurs when the driver fails to initialize a FC-VI port.
- Corrective Action
Reboot the controller. Contact NetApp technical support if the problem persists.
- Syslog Message
FC-VI adapter: %s failed for port %s.
- Parameters
operation (STRING): Type of operation
port (STRING): FCVI Interconnect NIC.
