ONTAP EMS reference
hypervisor.version events
hypervisor.version EMS events occur when the version of the hypervisor is not supported by ONTAP® Select.
hypervisor.version
Severity
ALERT
This message occurs when the version of the hypervisor is not supported by ONTAP® Select.
Corrective Action
Move ONTAP® Select to a supported hypervisor version.
Syslog Message
Unsupported hypervisor version: %s. Supported versions: %s
version (STRING): Current version of the hypervisor.
supported_versions (STRING): Supported versions of the hypervisor.
