lun.metafile events
lun.metafile.dirCreateFailed
- Severity
ERROR
- Description
lun metafile directory creation failed
- Corrective Action
Check available space on the volume and make sure that the volume is not full or close to full.
- Syslog Message
Couldn’t create vdisk metafile directory %s.
- Parameters
path (STRING): path for the metafile directory that Data ONTAP failed to create
lun.metafile.OOVC.corrupt
- Severity
ERROR
- Description
This message occurs when inconsistent blocks are read while reading or writing to the Out Of Volume Container (OOVC) metafile. The OOVC metafile contains certain LUN and NVMe namespace configuration and metadata for the objects in a given volume. SAN management operations might be impaired while the OOVC is in this state.
- Corrective Action
Use the 'lun rescan -build-oovc' command to rebuild the OOVC metafiles for the affected volume.
- Syslog Message
RAID error inconsistency was received for the OOVC metafile in volume %s (DSID %llu).
- Parameters
volume_name (STRING): Name of the volume for which the OOVC metafile was found to be inconsistent.
volume_dsid (LONGINT): Data set ID (DSID) of the volume for which the OOVC metafile was found to be inconsistent.
lun.metafile.VTOC.corrupt
- Severity
ERROR
- Description
This message occurs when inconsistent blocks are read while reading or writing to the Vdisk Table of Contents (VTOC) metafile. The VTOC metafile contains the inventory of LUNs and NVMe namespaces in a given volume. SAN management operations might be impaired while the VTOC is in this state.
- Corrective Action
Use the 'lun rescan -build-vtoc' command to rebuild the VTOC metafile for the affected volume.
- Syslog Message
RAID error inconsistency was received for the VTOC metafile in volume %s (DSID %llu).
- Parameters
volume_name (STRING): Name of the volume for which the VTOC metafile was found to be inconsistent.
volume_dsid (LONGINT): Data set ID (DSID) of the volume for which the VTOC metafile was found to be inconsistent.
