mcc.drmsg events
mcc.drmsg.received
- Severity
INFORMATIONAL
- Description
This message occurs when a DR message is successfully received from a DR partner node.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
version (INT): Version of the DR message.
type (STRING): Type of message sent.
request (STRING): Type of request being sent.
seq_num (LONGINT): Sequence number of the message.
recv_sysid (LONGINT): System ID of receiving Node
sysid (LONGINT): System ID of sending node.
recv_time (LONGINT): Time when message was sent.
send_time (LONGINT): Time when message was sent.
status (STRING): Status of the DR message.
fsm_state (STRING): FSM state of the responding node.
sb_reason (STRING): SB reason if any specified.
dr_op_state (INT): DR operation state of the responding node.
ha_fw_state (STRING): HA firmware state of the responding node.
mcc.drmsg.sent
- Severity
INFORMATIONAL
- Description
This message occurs when a DR message is successfully sent to a partner node.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
sysid (LONGINT): System ID of sending Node.
