ONTAP EMS reference
mgmt.cr events
mgmt.cr.constituent.added
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
INFORMATIONAL
This message occurs when a constituent volume is added to the Infinite Volume.
Corrective Action
(None).
Syslog Message
Constituent volume "%s" has been added to Infinite Volume "%s" in Vserver "%s". Its size is %ld bytes.
constituentName (STRING): Name of the added volume.
repositoryName (STRING): Name of the Infinite Volume.
vserverName (STRING): Name of the Vserver.
size (LONGINT): Size of the added volume.
mgmt.cr.constituent.deleted
Deprecated
Severity
INFORMATIONAL
This message occurs when a constituent volume is deleted from the Infinite Volume.
Corrective Action
(None).
Syslog Message
Constituent volume "%s" has been deleted from the Infinite Volume "%s" in Vserver "%s".
constituentName (STRING): Name of the deleted volume.
mgmt.cr.constituent.failure
Deprecated
Severity
ERROR
This message occurs when an Infinite Volume operation that operates on the constituent volumes succeeds, but fails on an individual constituent.
Corrective Action
Fix the cause of the failure listed in the error, and then run the command again.
Syslog Message
Repository job "%s" run on Infinite Volume "%s" in Vserver "%s" failed for constituent volume "%s": %s
jobName (STRING): Name of the repository job.
constituentName (STRING): Name of the constituent volume.
reason (STRING): Reason for the failure.
mgmt.cr.constituent.resized
Deprecated
Severity
INFORMATIONAL
This message occurs when an Infinite Volume constituent volume is resized.
Corrective Action
(None).
Syslog Message
Constituent volume "%s" of Infinite Volume "%s" in Vserver "%s" has been resized to %ld bytes.
constituentName (STRING): Name of the resized volume.
size (LONGINT): New size of the volume.
mgmt.cr.job.failed
Deprecated
Severity
ERROR
This message occurs when a repository job fails.
Corrective Action
Fix the cause of the failure, listed in the error, and run the command again.
Syslog Message
Repository job "%s" has failed for Infinite Volume "%s" in Vserver "%s": %s
mgmt.cr.job.succeeded
Deprecated
Severity
INFORMATIONAL
This message occurs when a repository job is completed successfully.
Corrective Action
(None).
Syslog Message
Repository job "%s" has succeeded for Infinite Volume "%s" in Vserver "%s": %s
reason (STRING): Success message of the job.
mgmt.cr.missing.footprint
Deprecated
Severity
ERROR
This message occurs when Data ONTAP® is attempting to create or expand an Infinite Volume and cannot retrieve volume footprint information about a volume. The footprint information for all volumes on aggregates used by an Infinite Volume, even those in other Vservers, must be known to safely create or expand an Infinite Volume.
Corrective Action
Ensure that the volume is healthy and online, and then retry the operation.
Syslog Message
Unable to get footprint information about volume "%s" in Vserver "%s".;
constituentName (STRING): Name of the volume for which footprint information could not be retrieved.
vserverName (STRING): Name of the Vserver the volume belongs to.
Looking for answers?
Try Doc, our Gen AI Assistant.
