ONTAP EMS reference
monitor.disklabelcheckfailed events
monitor.disklabelcheckfailed EMS events occur when the system detects that a file system disk has an invalid or a missing RAID label.
monitor.diskLabelCheckFailed
Severity
NOTICE
This message occurs when the system detects that a file system disk has an invalid or a missing RAID label. The system corrects the situation during the next label update.
Corrective Action
No user action is required.
Syslog Message
Periodic check of RAID %s has failed. The system will correct the problem.
disk_info (STRING): Formatted information of the disk object.
label_block_num (INT): Label block number code.
label_state (INT): Label state code.
label_read_error (INT): Label read error code.
shelf (STRING): Disk shelf identifier where the disk is located.
bay (STRING): Disk bay within the disk shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model string of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk in RPM.
