ONTAP EMS reference
netif.phyoperationfailed events
netif.phyoperationfailed EMS events occur when there is a failure in reading or writing the physical layer (PHY) of a network interface.
netif.phyOperationFailed
Severity
ERROR
This message occurs when there is a failure in reading or writing the physical layer (PHY) of a network interface.
Corrective Action
This might be caused by a software bug. If there are problems with the interface after seeing this message, replace the component associated with the network interface (PCIe card or controller motherboard). If the problem persistis, contact NetApp technical support.
Syslog Message
Failure in reading or writing PHY for network interface %s. Driver=%s, error=%d, regaddr=0x%x, command=0x%x, status=0x%x.
ifName (STRING): Name of the network interface; for example, "e2a".
driver (STRING): Driver name.
error (INT): Error code.
regaddr (INTHEX): PHY register address.
command (INTHEX): PHY command.
status (INTHEX): PHY status.
