nvmeof.portiomb events
nvmeof.portiomb.clear
- Severity
NOTICE
- Description
This message occurs when there are no longer two ports cabled incorrectly from a node to bottom module (B) on a shelf.
- Corrective Action
(None).
- Syslog Message
Two ports are no longer cabled incorrectly from node %s to bottom module (B) on shelf with SN %s.
- Parameters
node_name (STRING): Host port connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.portiomb.error
- Severity
ERROR
- Description
This message occurs when there are two ports cabled to the bottom module (B) on a shelf.
- Corrective Action
Connect two ports to different modules to provide redundancy.
- Syslog Message
There are two ports cabled from node %s to bottom module (B) on Shelf with SN %s. One of these cables should be removed.
- Parameters
