perfstatd.dir events
Creating your file...
Your file is ready
perfstatd.dir.permission
- Severity
ERROR
- Description
This message occurs when the perfstat daemon (perfstatd) startup fails due to improper permissions for the '/mroot/etc/log' directory. This failure impacts the continuous archiving of performance data that technical support uses to troubleshoot performance issues.
- Corrective Action
Verify that the permissions of the '/mroot/etc/log' directory are 'rwxr-xr-x' by executing the 'fsecurity show /vol/vol0/etc/log' command from the nodeshell. After correcting the permissions for this directory, restart perfstatd by executing the 'spmctl -e -h perfstatd' command from the freebsd shell.
- Syslog Message
The perfstat daemon startup failed due to improper directory permissions.
- Parameters
(None).
