qtree.delete events
qtree.delete EMS events occur when ONTAP encounters issues associated with qtree deletion operations.
qtree.delete.failed
- Severity
ERROR
- Description
This message occurs when the delete operation on a qtree fails.
- Corrective Action
Check and resolve the failure reason and attempt the qtree deletion again.
- Syslog Message
Failed to delete qtree "%s" in volume "%s" on Vserver "%s". Error: "%s" (%d).
- Parameters
qtree (STRING): Name of the qtree.
volume (STRING): Name of the volume on which the qtree resides.
vserver (STRING): Name of the Vserver on which the volume resides.
reason (STRING): Reason for the failure.
errorCode (INT): Error number of the failure.
qtree.delete.start
- Severity
NOTICE
- Description
This message occurs when a qtree is being deleted. A subsequent event will indicate the success or failure of the operation.
- Corrective Action
(None).
- Syslog Message
Deleting qtree "%s" in volume "%s" on Vserver "%s".
- Parameters
qtree.delete.success
- Severity
NOTICE
- Description
This message occurs when the delete operation on a qtree succeeds.
- Corrective Action
(None).
- Syslog Message
Successfully deleted qtree "%s" in volume "%s" on Vserver "%s".
- Parameters
