ONTAP EMS reference
rdma.rlib events
rdma.rlib EMS events occur when ONTAP encounters issues associated with the high-availability (HA) interconnect advertisement service.
rdma.rlib.adv.failed
Deprecated
Deprecated as of ONTAP 9.1 because this platform is no longer supported.
Severity
ERROR
This message occurs when the system fails to start the advertisement service for the high-availability (HA) interconnect.
Corrective Action
Contact NetApp technical support.
Syslog Message
Failed to start the advertisement service on HA interface %s.
if_name (STRING): Name.
rdma.rlib.config.if.failed
Deprecated
Severity
ERROR
This message occurs when configuration for the high-availability (HA) interface fails.
Corrective Action
Syslog Message
Failed to configure the HA interface %s.
if_name (STRING): Interface name.
rdma.rlib.get.if.failed
Severity
ERROR
This message occurs when the system cannot find high availability (HA) capable interface.
Corrective Action
Syslog Message
No HA Interconnect capable interface was found.
(None).
rdma.rlib.listen.failed
Severity
ERROR
This message occurs when the system fails to start the listener for the HA interface.
Corrective Action
Verify that link status is up by running the "metrocluster interconnect adapter show" command. Also check the FC-VI connectivity between DR partners. If the issue persists, contact NetApp technical support.
Syslog Message
Failed to start listener for the HA interconnect on interface %s.
rdma.rlib.queue.full
Severity
NOTICE
This message occurs when the send or receive queue of a Queue Pair (QP) is full.
Corrective Action
(None).
Syslog Message
%s queue of QP %s is full.
send_or_recv (STRING): Send or receive queue of a QP.
qp_name (STRING): QP name.
