ONTAP EMS reference
rsh.enabled events
rsh.enabled EMS events occur when rsh is enabled in the cluster using the (privilege: advanced) "security protocol" command.
rsh.enabled
Severity
NOTICE
This message occurs when rsh is enabled in the cluster using the (privilege: advanced) "security protocol" command.
Corrective Action
(None).
Syslog Message
Insecure protocol service rsh has been enabled in the cluster.
(None).
